Is there a separate fluid tank for the rear windshield washer?
230,000 MILES • 3.3L • 4 CYL • 2WD • AUTOMATIC
TED IRELAND
If so, where is it located? Thank you.
Mar 13, 2022 at 12:22 AM
No. There is not a separate reservoir for the rear system. It is the same one for the front and just has a line running to the rear and a pump that pushes the fluid to the rear for the rear motor to spray it on the window.
I attached the info and the wiring diagram in case you need this info.
Here is a guide that will help with any testing that you need to do:
Please let us know what other questions you have on this.
Thanks
Mar 13, 2022 at 4:53 AM
TED IRELAND
Thank you very much. I appreciate all the help. :)
Mar 15, 2022 at 4:23 AM
You are welcome. Please come back next time you need some info.
Thanks for using 2CarPros
Mar 15, 2022 at 11:30 AM
