Rear transmission mount replacement?
192,364 MILES • 3.4L • V6 • 2WD • AUTOMATIC
RALPHP1254
  • 22 POSTS
My rear mount has gone bad, and I was wondering what all has to be done to replace it. I don’t have a lift, but I do have jack stands and a jack as well.
Mar 13, 2025 at 2:12 AM
CANNON1349
  • 861 POSTS
Hello, here is the procedure for the rear transmission mount. Diagrams will also be attached at the bottom.
REMOVAL
(SEE IMAGE 1)
1. Raise the vehicle.
2. Remove the left front wheel.
3. Remove the front fender liner.
4. Remove the mount thru bolt (1). (SEE IMAGE 2)
5. Remove the mount bolts.
6. Remove the mount.
INSTALLATION
1. Install the mount.
2. Install the mount bolts.
^ Tighten the bolts to 122 Nm (90 ft. lbs.).
3. Install the mount thru bolt (1).
^ Tighten the bolt to 120 Nm (89 ft. lbs.).
4. Install the front fender liner.
5. Install the left front wheel.
6. Lower the vehicle.
Please let us know how it turns out,
William
Mar 13, 2025 at 11:30 AM
