Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Tires
Replace/Remove
Rear tires will not move
1995 FORD F-150
130,000 MILES • 5.8L • V8 • 4WD • AUTOMATIC
KERRY GANN
MEMBER
We changed the rear U-joint, now back tires will not move.
Sep 19, 2017 at 3:41 AM
MIKE H R
MEMBER
make sure the alignment of the u-joint. make sure the car is in neutral. in park they would not turn.
Sep 19, 2017 at 6:43 AM
KERRY GANN
MEMBER
Sep 19, 2017 at 7:17 AM
Experienced Mechanic
Do both rear tires not turn? Is the ebrake on? I was thinking you may have too long of bolt in the pinion flange?
Can you send a picture of the flange with the drive shaft bolted up please?
Cheers, Ken
Sep 20, 2017 at 5:56 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
