Rear tires will not move
130,000 MILES • 5.8L • V8 • 4WD • AUTOMATIC
KERRY GANN
We changed the rear U-joint, now back tires will not move.
Sep 19, 2017 at 3:41 AM
MIKE H R
  • 3,094 POSTS
make sure the alignment of the u-joint. make sure the car is in neutral. in park they would not turn.
Sep 19, 2017 at 6:43 AM
KERRY GANN
Sep 19, 2017 at 7:17 AM
  • 55,746 POSTS
Do both rear tires not turn? Is the ebrake on? I was thinking you may have too long of bolt in the pinion flange?
Can you send a picture of the flange with the drive shaft bolted up please?
Cheers, Ken
Sep 20, 2017 at 5:56 AM
