Rear tires wearing on the inner edge
215,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
TGUNDO2003
  • 5 POSTS
The rear tires are wearing on the inner edge of the tire evenly with no cuppung. The tires seem to be "leaning" in at the top. I am guessing some type of worn suspension part from age/mileage. Need advice on what to check for replacement. It doesnt bounce so I dont think its shocks, but I think that it is an air chock system so i am not sure.
Apr 4, 2014 at 11:05 AM
  • 110,248 POSTS
the rear wheels can be aligned with the front. Have that checked. The mechanic may need to add shims to get the proper alignment.
Apr 4, 2014 at 12:05 PM
TGUNDO2003
  • 5 POSTS
Ok thanks. I'll bring it up to the local guy and see if it is that simple. I hope so...
Apr 5, 2014 at 2:02 AM
  • 110,248 POSTS
It really isn't that big of a job. However, many shops charge a good bit for each shim they have to add. Let me know if you have other questions.
Apr 5, 2014 at 11:45 AM
