Rear taillight fuse keeps blowing
1996 LEXUS ES 300
150,000 MILES • 3.0L • 6 CYL • AUTOMATIC
WALLY AB
  • 97 POSTS
Reverse lights work, taillight fuse 15 amp, kept blowing. Now it seems fine, even after I turned it on and off a few times, and replaced a few fuses, but before it kept blowing right away when any power was fed to it through the fuse.
Only thing I did was tape one 30a jcase fuse that was broken in one of the fuse box, since I couldn't find one late on a Sunday.
Mar 17, 2019 at 10:58 PM
JOETECHPRO
  • 705 POSTS
Hey WALLY AB,
For a fuse to blow there needs to be excess current draw on that circuit.
Generally caused by a short in a wire/component.
Can you please describe which fuses you have replaced.
Have you replaced a fuse with a higher rating than the original?
Regards, Joe
Mar 18, 2019 at 11:42 AM
