Rear tail lights
75,000 MILES • 2WD
DGENNARO
  • 6 POSTS
Lower rear tail light RT side. 1: The vertical red light is out. Is that a LED or a bulb. 2: Is there a short cut for replacing the lower light unit? Do I really have to take the whole bumper cover off in order to replace it?
Mar 10, 2019 at 7:33 AM
SCGRANTURISMO
  • 4,897 POSTS
I have included in the diagrams down below the step by step instructions for removing the rear tailight assembly, recalibration of the sensors, and disassembling the taillights. Please feel free to ask us any other questions you may have.
P.S. Please be patient.The instructions are quite long.
Thanks,
Alex
2CarPeos
Mar 11, 2019 at 12:58 AM
DGENNARO
  • 6 POSTS
What ever happened to just changing a bulb? This is not like the old days. Can the sensors be adjusted after I put the cover back on? The reason I ask is because I cannot perform this on level ground. It looks like I'll have to take it to Toyota after I replace the tail light. This is both helpful and discouraging at the same time. Goodbye shortcut.
Mar 11, 2019 at 6:00 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
I agree whole heartedly. I am sorry about that, and more bad news, that is all the info I have on the subject. But it is the instructions from Toyota, so there will not be any more definitive instructions on how to do it.
Thanks,
Alex
2CarPros
Mar 11, 2019 at 10:14 AM
DGENNARO
  • 6 POSTS
Thanks, it was very helpful. I can put the light in then I'll have Toyota do the rest.
Mar 11, 2019 at 11:27 AM
  • 55,837 POSTS
I think this video will help it shows how to change the bulbs:
https://youtu.be/KNqxFEoNcrc
Mar 14, 2019 at 8:01 AM
DGENNARO
  • 6 POSTS
I just got the light today and it looks so simple as an assembly. However, I cannot see any other way of installing it then a very long procedure of removing the rear bumper cover. It looks like a years work. Other than what you have given me it looks like there is nothing further that you can do. Thanks
Mar 15, 2019 at 6:57 AM
DGENNARO
  • 6 POSTS
It took me less than an hour to install the light. As I started at the right wheel well there was a black lip that was under the Quarter panel and as I was removing the retainer clip the rear cover looked like it could unsnap. I pulled on it and it unsnapped enough to where I could see the entire rear light. I removed the retainers under that portion of the cover and I was able to remove the old light and installed the new one. After which I snapped the cover back and replaced the retainers. I never touched the sensors nor were there any in that area. My total cost of the used tail light was $109.00. and less than an hour to install. I cannot understand why the dealer quoted me $740.00 for the job.
Mar 16, 2019 at 12:28 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Great job! I love to hear success stories like yours. Dealerships are pricey, but you know that your vehicle is fixed, and fixed right usually with a warranty.
Thanks,
Alex
2CarPros
Mar 16, 2019 at 6:35 AM
  • 55,837 POSTS
Use 2CarPros anytime, we are here to help. Please tell a friend.
Mar 17, 2019 at 8:41 AM
