Rear left brake light not working. Running lamps work but no brake light.
Mar 14, 2018 at 6:22 AM
✓Experienced Mechanic
Have you tested the globe? and check for power at the globe holder and also check that the earth is okay, if the other light is okay, the problem will probably be at that light.
Mar 14, 2018 at 6:56 PM
MICAH ROGERS2
MEMBER
Actually no. But I will check and get back.
Mar 15, 2018 at 7:21 AM
Okay, always best to check the basics first.
Mar 15, 2018 at 9:11 AM
MICAH ROGERS2
MEMBER
I do not have voltage at the lamp when the brake pedal is pressed. I would run a jumper from the left brake light to the right but I do not think that would work since both the tail lights are separate runs altogether.
Mar 16, 2018 at 12:30 AM
MIKE H R
MEMBER
most common things are a bad ground {even if they look good} a broken wire or a bad brake light switch,
