Rear spark plugs and wires
214,744 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
JEIGABROADT
I am having a hard time getting the rear spark plug wires off. Do you have any tips or suggest any too that would help? I have twisted and pulled on the wires as hard as I possibly could. I have tried with a spark plug wire wrench as well and they would not budge. Thanks for any suggestions!
Aug 25, 2017 at 11:13 AM
CJ MEDEVAC
  • 11,000 POSTS
If you have room,
What about a pair of these?
https://shop.advanceautoparts.com/p/k-tool-international-spark-plug-boot-pliers-kti70750/22984488-P?searchTerm=spark+plug+pliers
There are other styles and brands.
The Medic
Aug 25, 2017 at 12:10 PM
JEIGABROADT
I have tried those. I cannot get the right angle on them to pull the boot off of the plug. I have tried just about everything it is beginning to get a bit frustrating.
Aug 25, 2017 at 12:31 PM
CJ MEDEVAC
  • 11,000 POSTS
If they are made from a "giving" kind of material,
Can you stick them in a vise/some sort of crack and bend the end into a usable angle?
The Medic
Aug 25, 2017 at 12:36 PM
STEVE W.
  • 15,418 POSTS
If you are replacing the wires just cut them with a knife to split the boot. Grab them with a pair of needle nose pliers and twist them like you are unscrewing a bolt. They can get stuck real bad.
Aug 25, 2017 at 2:49 PM
