What is the angle of the shock is mounted to the axle frame?
55,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
GZHAWK
I can't find anywhere what the angle of the shock is mounted to the axle frame. If you know anything, please let me know! Thank you
Jan 26, 2024 at 2:49 AM
  • 55,694 POSTS
That is because it changes with the suspension moment. What are you trying to do? Please check out the images and video below.
https://youtu.be/-CRHmP9peco?si=pau6AFa1H558SXKE
Check out the images (below). Let us know if you need anything else.
Jan 26, 2024 at 4:21 AM
