rear shock
80,000 MILES
WILLIESIMMONS
how to replace rear shock on 2007 vw passat
Apr 18, 2013 at 8:18 AM
Front Wheel Drive (FWD)
Shock Absorber
¤ Adaptive chassis DCC shock absorber, removing and installing, refer to => [ Shock Absorber, FWD ] See: Suspension Strut / Shock Absorber\Service and Repair\Removal and Replacement\Self-Leveling Suspension\Shock Absorber, FWD.
Special tools, testers and auxiliary items required
¤ Torque wrench (V.A.G 1332)
Removing
Remove wheel.
Remove wheel housing liner.
Remove coil spring. Refer to => [ Coil Spring ]. See: Coil Spring
Remove bolts - arrows -.
Remove bolt - arrow -.
Remove shock absorber.
Installing
Installation is performed in the reverse order of removal. Observe the following when doing so:
¤ The bolted connections of the shock absorber to the wheel bearing housing must only be fastened when the dimension - a - is achieved! => [ Measure Dimension ] See: Front Wheel Drive (FWD).
Insert shock absorber and tighten bolts - arrows -.
Tighten bolt - arrow -.
Install coil spring. Refer to => [ Coil Spring ]. See: Coil Spring
Install wheel housing liner.
Install wheel and tighten. Refer to => [ Tightening Specification for Mounting Wheels ] See: Wheels and Tires\Wheel Stud / Lug Nut\Specifications\Tightening Specification For Mounting Wheels.
Apr 18, 2013 at 8:09 PM
