Rear Shim
21,000 MILES
IRISHROSE15
I had all four tire changed today and was told that the right rear needs a shim. The cost is 90.00(parts and labor) Is that reasonable? Before i have it repaired I wanted to check the price too see if it's reasonable or are they taking advantage of my gender.
May 18, 2013 at 8:00 AM
Shim??? for what???? are you having an alignment done???? if you are, that makes sense and the price is in the ball park
May 18, 2013 at 8:20 AM
IRISHROSE15
Thanks Roy,
I do need an alignment, I did not mention that. They did the front yesterday with the tires.
May 19, 2013 at 12:13 AM
