Stiff rear ride. Sill panels appear level to ground. Level sensor rod intact and connected. Pump not charging shocks for past several months. New rear air shocks and front shocks year ago, and pump worked then. Could this be a stuck or bad exhaust valve? Where is it located? How to test and replace? What activates the exhaust valve and could that be the problem?
Many thanks - Chris
Many thanks - Chris
Sep 24, 2019 at 10:08 AM
