My rear running lights are not working but brake lights, turn signals, and reverse lights all work fine.
Jan 27, 2019 at 4:27 AM
SCGRANTURISMO
✓Experienced Mechanic
Brenden McKay, my name is Alex and I will be helping you today. It sounds to me like you might have a burned out bulb. Here is a helpful link to explain how to track down and fix the problem and some wiring diagrams for your vehicle. Thanks, and let us know if we can help more with this or any other questions you may have. https://www.2carpros.com/articles/no-tail-lights-exterior-running-lights-tail-lights-out
Images (Click to enlarge)
Jan 27, 2019 at 4:18 PM
BRENDAN MACKAY
MEMBER
Sorry. Should have included that all of the bulbs are new, as well as both tail light assemblies. I have also checked and replaced the fuse.
Jan 27, 2019 at 11:06 PM
SCGRANTURISMO
Are your license plate lamps working?
Jan 27, 2019 at 11:20 PM
BRENDAN MACKAY
MEMBER
No but the upper light above the back window works intermittently
Jan 28, 2019 at 1:07 AM
SCGRANTURISMO
Have you checked the Body Control Module?
Image (Click to enlarge)
Jan 28, 2019 at 1:33 PM
BRENDAN MACKAY
MEMBER
I did. Replaced the relays too but still nothing.
Jan 29, 2019 at 2:02 AM
SCGRANTURISMO
Do you have a trailer towing package?
Jan 29, 2019 at 9:52 AM
BRENDAN MACKAY
MEMBER
There is a hitch installed but I do not think it is wired for a trailer. I bought it used and the previous owner never used it.
Jan 29, 2019 at 9:24 PM
SCGRANTURISMO
Okay. Have you also checked the stop light switch and splice 311 and 313? You can find these on the original wiring diagram I sent you.
