Rear right passenger door wont open
150,000 MILES • AUTOMATIC
EDGAR ARMENTA
  • 27 POSTS
The door on my vehicle wont open from either side, it is as if the lock does not seem to actuate when pulling the pin or pressing the unlock button. I pull the lever and you can hear the rod move, but it does not open the door. i have removed the panel from the inside, the doors shut and I cannot seem to find anything inside that will let me open the door. thanks in advance.
Aug 13, 2016 at 3:40 AM
HMAC300
  • 48,601 POSTS
check to see if cable or rad is moving you may have a clip that has fallen off or broken we have no pictures to help on this
Aug 15, 2016 at 12:36 AM
EDGAR ARMENTA
  • 27 POSTS
I found out later that it was a broken spring from the outer door handle, wouldn't open from the inside because it had the child safety lock on, but I replaced the spring and it would open again, thanks anyhow
Aug 19, 2016 at 2:52 PM
HMAC300
  • 48,601 POSTS
least you found it and it's fixed
Aug 19, 2016 at 10:41 PM
