Rear passenger side caliper will not compress
291,741 MILES • 5.4L • V8 • 2WD • AUTOMATIC
ROYCAR71
  • 359 POSTS
Doing a brake pad change I cannot compress back brake caliper. It appears to be leaky around rubber grommet area of piston. Do I need to replace it?
Nov 24, 2018 at 9:46 AM
  • 110,248 POSTS
Yes, it sounds like the caliper piston has worn, become stuck, and is now leaking. It should be replaced.
Here is a link that shows how one is replaced:
https://www.2carpros.com/articles/brake-caliper-replacement
Let me know if you run into trouble or have other questions.
Nov 24, 2018 at 10:25 AM
ROYCAR71
  • 359 POSTS
Thanks, I am on my way to AutoZone for replacement.
Nov 24, 2018 at 10:32 AM
  • 110,248 POSTS
Happy to help. Let me know if you have other questions or need help with anything.
Nov 24, 2018 at 11:48 AM
