rear passanger side window won't go down
107,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
DEAN35
replaced window regulator 6 months ago. worked fine. Now I have no power to back window. fuses are checked and good control on front driver door only one electric unit lit up. front windows work fine. seems to be electric issue? No power to back door panel controlling the window Radio speaker in door panel has power.
Nov 18, 2014 at 1:56 AM
  • 110,251 POSTS
Check for broken wires between the door pillar and where the wiring enters the door.
Nov 18, 2014 at 2:01 AM
