rear oil seal on transfer case
104,000 MILES
TIMOTHYS6858
how to remove harmonic balancer on rear cone of transfer case to change rear oil seal.
Apr 23, 2013 at 3:22 AM
CJ MEDEVAC
  • 11,000 POSTS
I HAVE THE 1979 PAPER AMC JEEP SERVICE MANUAL......I SHOULD BE SHOT FOR NOT TAKING CARE OF IT WHEN IT 1ST FELL INTO MY LAP BACK IN 1983
I REALLY HATE IT................... THAT AS SOON AS I GIVE UP THE "ARK", YOU WILL NOT NEED ME FOR ANY MORE BASIC STUFF
SO.......THESE MANUALS ARE WRITTEN VERY WELL......IT DON'T "FORGET" AND LEAVE OUT STUFF EITHER, LIKE I MIGHT, OR ANYONE ELSE RUNNING ONLY ON MEMORY
IF YOU WILL REALLY SLOWLY POUR OVER THE TROUBLESHOOTING STUFF---AND INSURE IT IS THE CORRECT ITEM AND THE CORRECT VEHICLE YOU ARE READING ABOUT........(MY '79 MANUAL INCLUDES ALL OF THE JEEP VEHICLE---CJ-CHEROKEE-TRUCK ALL SORTA INTER-TWINED)
OK HERE'S THE DEAL---MORRIS 4X4 HAS SQUARED US AWAY.......MAINLY YOU!........I HAVE THE PAPER ONE
I RECKON TO SAVE SPACE--THEY DID NOT COPY 'EM ALL, IF THE SAME INFO WAS UP OR DOWN A YEAR
SO GO THERE!
SCROLL A LITTLE TO "ONLINE REPAIR MANUAL"
SELECT "YOUR VEHICLE"
SELECT "THE YEAR"........REMEMBER, YOU MAY HAVE TO SELECT A YEAR ABOVE OR BELOW YOURS....THE INFO WITHIN IS MOST LIKELY THE SAME
SELECT "THE AREA OF YOUR JEEP YOU ARE DEALING WITH"
NOW, YOUR INFO IS DOWN A LITTLE BIT
NOW SCROLL THE WHOLE PAGE DOWN TO THE NEXT BLOCK/SECTION
YOU ARE IN!!!!!!
LOOK AT TROUBLESHOOTING REALLY GOOD---AS WELL AS TESTING
THE WHOLE JEEP SHOULD BE THERE!
IF YOU LOOK CLOSE AT SOME OF THE DIAGRAMS---THEY DO SHOW A LITTLE BIT OF THE CABLES
YOU CAN EVEN PRINT PAGES!
WHAT A DEAL!!!
IF YOU NEED SOME INTERPRETATION COME BACK TO THIS POST!........ALTHOUGH I'M A CJ GUY, MAYBE I CAN HELP
AM I NOT THE COOLEST FELLER YOU EVER MET ONLINE????
DID I DO GOOD?
.....I'M NOT UP ON THE NEWER WRANGLERS, MAYBE THE "HARMONIC BALANCER" IS NOT THE CORRECT TERM FOR WHATEVER YOU ARE DESCRIBING ON THE TRANSFER CASE............"THE KNOWLEDGE BASE" WILL REALLY AID YOU FROM HERE ON OUT.
LET ME KNOW WHAT YOU THINK ABOUT "TKB"
THIS IS WHERE I EXCEL.....THE CJs!
https://www.2carpros.com/questions/1985-jeep-cj7-inconsistent-curb-idle-low-power-hi-rpms
AND THIS ONE?
https://www.2carpros.com/questions/1982-jeep-cj7-ignition-problem-spark-distributor-cap
YOUR TURN
THE MEDIC
Apr 23, 2013 at 9:44 AM
