No Reverse
124,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
JPLCYAN
My mechanic changed a second hand automatic transmission and it works fine until i got a problem with the rear mode. The car moves very slowly on flat road only and it shakes sometimes. But will never move backward if the car is in a slight way down position or even a hump at the back.
The mechanic change the solenoids but still the same. At last i was advised to get a complete set of joints for the transmission and need a specialist to do the works. Are there any other problems that might cause the rear mode to be inefficient.
Thanks for your help.
Jean Pierre
Dec 27, 2017 at 2:02 AM
  • 55,758 POSTS
There are a couple things we need to do first run the codes to see what comes up you may have a input shaft speed sensor that is out or the wrong fluid was installed which can make this malfunction as well.
Here is a guide to help us get started:
Cheers, Ken
Dec 28, 2017 at 6:35 AM
JPLCYAN
Thanks a lot Ken. I will Forward the link to the mechanic. May be he missed something when repairing.
Dec 28, 2017 at 11:59 AM
  • 55,758 POSTS
Cheers, Ken
Dec 31, 2017 at 3:23 AM
