Rear mian bearing remove and replace
130,000 MILES
TY912
Would I have to take the motor is a 350,,2pices seal will it cum out
Or would I have to drop the crank and Change it
Apr 18, 2013 at 5:10 AM
oil pan has to be dropped. rear main cap removed and the other loosened for access to the upper part of the seal. make sure the bearing is good.. if it is not, the seal will leak
Apr 18, 2013 at 9:02 AM
