change the rear main and oil pan gasket?
230,000 MILES • 3.7L • V6 • 2WD • AUTOMATIC
TANKK2014
  • 29 POSTS
Does anyone have a link to a video for my specific model on how to change the rear main and oil pan gasket? I can't seem to find one. The process seems straight forward but I don't want to miss any tricks. Thank you.
Nov 11, 2025 at 10:26 PM
  • 55,743 POSTS
Sure, here is a video that shows how to change out the oil pan,
https://youtu.be/lasKM_w7Rpg?si=M48nttBBw9GawrpN
For the rear main seal the transmission will need to be removed. Here are two guides that will show you step by step what to do to get the job done. This video shows the work being done on a similar car which the process is very similar for you truck.
https://www.youtube.com/watch?v=3vJAojsrfuU
Here is the rear main seal, like I say the job is very similar to your truck
https://www.youtube.com/watch?v=Fh12SPwrHrk&pp=0gcJCQMKAYcqIYzv
Check out the images (below). Let us know if you need anything else.
Nov 13, 2025 at 3:07 AM
