Rear lower control arm torque specs needed
115,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
SEAN PEDONE
  • 10 POSTS
I have searched and searched for an online video going through a replacement of the rear control arms. on the car listed above SL Sedan. Does anyone know the torque specs for this job or have a how to video link they can share?
Jun 8, 2021 at 9:52 AM
I am attaching the info below on the process from the manual on how to replace it and the torque spec.
Here is a guide that will help with step by step instructions.This is a different vehicle but the process is similar.
https://www.2carpros.com/articles/lower-control-arm-bushing-replacement
Please run through this material and let us know if you have other questions. Thanks
Jun 9, 2021 at 12:07 PM
SEAN PEDONE
  • 10 POSTS
Thank you. Got it completed. A bit tough to do just jacking the car up at home but was successful. Took it in for a full alignment and she rides like new again.
Jun 20, 2021 at 1:55 AM
That is great. Yes, these are not the easiest to do without a lift but I am so glad you got it figured out.
Please come back to 2CarPros in the future. Thanks
Jun 20, 2021 at 12:12 PM
