Rear wheels lock up and release randomly?
298,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
TENDER_LOINCOIN
The rear driver side wheel will lock up about every three meters. I do not touch the brake. It will slowly lock up the wheel then it will release, and repeat. I have no idea what could be causing this problem. I have replaced both rear calipers and bled all four brakes.
Nov 6, 2022 at 6:19 AM
  • 55,770 POSTS
It sounds like the differential is bad but to be sure let's jack up the rear of the car and spin the rear wheels, if when you rotate the wheels, they both turn in the same direction and the drive shaft turns as well, you have found the problem and the rear end needs to be replace/rebuilt.
Here is a guide to help:
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Please go over this guide and report back.
Nov 7, 2022 at 2:16 AM
TENDER_LOINCOIN
Hello! Thank you, I did some further experimenting and I have figured out, it drives great in first gear but when it shifts to second gear is when it locks up. It there a way to fix this?
Nov 7, 2022 at 12:16 PM
  • 55,770 POSTS
How does the vehicle drive in reverse? Did you try to spin the rear wheels if so what happened?
Nov 8, 2022 at 2:12 AM
TENDER_LOINCOIN
The rear wheels spin freely It drives fine in reverse It has enough transmission fluid Though the transmission fluid is a little burnt.
Nov 8, 2022 at 6:19 AM
  • 55,770 POSTS
I think you have a second gear planetary that has blown up inside the transmission, which is the only this that can stop the differential from turning. I would remove the transmission and have it rebuilt.
Here is a video to help you:
https://youtu.be/3vJAojsrfuU
Let us know what happens and please upload pictures or videos of the problem.
Nov 9, 2022 at 3:19 AM
