rear lights/wiring, and shifting seqence
888,273 MILES • 6.0L • V8 • 4WD • AUTOMATIC
SCRAP KING
i have a truck i am restoring and i dont know where p/n/d/d1/d2/ is on the side of the transmission?.
also sum dumb ass cut out the wires for the rear lights and now when i wired it in the light socket was hot and the flashers dident work really i nead some one to tell me witch wire is what there is 3 green wires and 1 yellow and 1 brown witch is witch
Apr 7, 2014 at 5:04 AM
JDL
  • 16,098 POSTS
The wiring info I found for this model year, says GMC, tail lamps. The wire colors are voltage.
Usually on the side of the tranny, forward all the way is park, next detent is reverse, next is neutral drive--drive 2--drive 1. I'm trying to do this from memory, I will double check if possible. If your under the vehicle working the shift linkage by hand, there safety issues. Make sure you have helper inside with their foot on the brake, incase my memory isn't that great, you don't want the vehicle taking off and running over you or somebody else, when you thought it was in park.
Safety is your responsibility.
Apr 7, 2014 at 7:04 AM
JDL
  • 16,098 POSTS
My info for your model year isn't great.
That shift pattern a/t I gave you should be universal for GM. Operatiing the shift linkage on side of tranny by hand, maybe this more clear, all the way clockwise should be park, One detent ccw is reverse, next detent ccw is neutral, Hopefully I got d--d2 and d1 correct.
Any shifting, be safe.
Apr 7, 2014 at 7:24 AM
