Drivers side brake light does not work?
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
JR. STROHM
Drivers side brake light doesn't work, blinker flashes fast. All bulbs and fuses are good no loose ground wires and flashers work normal.
Oct 24, 2024 at 3:06 AM
  • 55,748 POSTS
Yep, this happens when the flasher module goes out. here is the location so you can swap it out. Check out the images (below). Please let us know what happens.
Oct 24, 2024 at 4:09 AM
JR. STROHM
Thank you, that fixed it.
Oct 24, 2024 at 8:37 AM
  • 55,748 POSTS
Thanks for letting us know, we are here to help, please use 2CarPros anytime. Can you please leave us a rating? (copy entire link)
https://www.google.com/search?q=2carpros&gs_ivs=1#lrd=0x80dcd47364be5d0d:0xba091aa4209f4497,1,,,&tts=0
and
https://www.sitejabber.com/reviews/2carpros.com
Thank you ;)
Oct 25, 2024 at 3:48 AM
