Rear lights
2005 GMC
145,000 MILES
NARGEL
The brake lights stay on constantly. They never shut off. Also the reverse lights and back up alarm never work and I just can't seem to find the problem. I have power at the lights and I just can't seem to find where the problem is. I've replaced the bulbs and that did not solve the issue.
May 23, 2013 at 10:55 PM
HMAC300
  • 48,601 POSTS
if your brake lights stay on see if your switch is giving power all the time, it's connected to brake pedal bracket. it may be a bad switch check your fuses firstunderhood and dash, then check to see if neutral switch is sending power for backup lights or not.
May 23, 2013 at 11:34 PM
