Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
PT Cruiser
Exterior Light
Running Light
Fuse
None of the rear lights are working
2003 CHRYSLER PT CRUISER
80,000 MILES
CATHERINE SUAREZ
MEMBER
1 POST
Check fuses all are okay.
Jan 14, 2020 at 7:45 AM
Experienced Mechanic
Good morning,
I attached a diagram for you of the circuit.
You need to check the fuses for voltage to be sure power is available to the multifunction switch for turning on the lights.
Use a test light to check for voltage.
Images (Click to enlarge)
Jan 14, 2020 at 8:43 PM
Add image or video
Ask a new question
Engine won't start
Engine overheating
