rear blinker not working
105,000 MILES • 1.9L • TURBO • 2WD • MANUAL
GARRITY0116
driver rear indicator not working the left side is ok and indicator runs nice and slow the right thinks it is in a disco ive changed the bulb and still nothing ive been told it might be an shorting problem and track the wire back to the connector and run a wire from the indicator to the connector but not knowing which wire I'm reluctant to do this without help
Mar 27, 2017 at 2:33 AM
  • 55,770 POSTS
Can you please check the front blinker to see if it is working, if the front bulb is out it will cause the rear bulb to blink fast.
https://www.2carpros.com/articles/turn-signals-blink-rapidly
Best, Ken
Mar 30, 2017 at 3:45 AM
