Rear hub assembly
114,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
HKFROMNY.
  • 112 POSTS
I have tried to get a decent video showing this procedure. I have worked on just about every car I have had, and this is a relatively easy job, but I want to double check with a master mechanic. I will get pictures and/or video for you if needed.
Sep 19, 2018 at 7:02 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
What is the question you are asking? I have attached a few pictures and a tutorial to view. Hope to hear from you soon and thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/bearing-hub-replacement
Sep 19, 2018 at 8:59 AM
HKFROMNY.
  • 112 POSTS
Here is a video. I hope it shows up good enough for ya'.
Sep 19, 2018 at 9:39 AM
HKFROMNY.
  • 112 POSTS
And every video I come across has rear disc brakes, mine has drum brakes.
Sep 19, 2018 at 9:42 AM
HKFROMNY.
  • 112 POSTS
Am I correct in my thinking, as mentioned in my video, that I should be able to just pop (beat) it out from the backside?
Sep 19, 2018 at 11:18 AM
DANNY L
  • 5,648 POSTS
Hello again.
Yes, that is correct. Maybe try using a spray type penetrant (PB Blaster or WD40 Blast) Or time for a bigger hammer!
Hope this helps and thanks again for using 2CarPros.
Danny-
Sep 19, 2018 at 12:00 PM
HKFROMNY.
  • 112 POSTS
Yup, your suggestions are exactly what I have been doing, back at it in morning. I will be in contact with further information, if I come across anything new. Thanks.
Sep 19, 2018 at 12:24 PM
DANNY L
  • 5,648 POSTS
Hello again.
Okay, let us know how things go. Thanks again for using 2CarPros.
Danny-
Sep 19, 2018 at 12:31 PM
