Rear hub and bearing replacement
161,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
CPERRY54
  • 35 POSTS
Making a roaring noise in the back driver rear. how do you replace?
Feb 24, 2020 at 1:02 AM
Please see the attachments and let me know if you have questions. Please notice that you will need an alignment after you complete the installation. Thanks
Feb 24, 2020 at 6:24 AM
CPERRY54
  • 35 POSTS
Sir, one other question. do you remove the spindle along with the hub and bearing,being it has too be pressed in?The pictorial is great.
Feb 24, 2020 at 11:54 AM
Spindle? I am not sure I follow which part you are talking about. Do you mean the axle shaft? I attached a picture pointing at the part I am talking about.
If this is what you are talking about, you do not have to remove the axle but the spline part at the end of it that has a nut holding it on the hub needs to be pushed out when removing the hub.
If this is not the part you are talking about, take a picture of it and I will get on the same page with you. Thanks
Feb 25, 2020 at 8:56 AM
