Rear heater core delete procedure
240,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
JAMIE007
How do I do a rear heater core delete on this van? The plumbing is rusted out. I did cut out the bad area and use 5/8 hose to repair a couple years ago, but it is leaking again. I am done trying to fix these rusted pipes. Can I just run a hose from the engine outlet pipe to the heater core, then from the heater core back to the thermostat? Do I need to use a "T" in there somewhere?
Jan 13, 2017 at 11:47 PM
DOCFIXIT
  • 18,828 POSTS
You have right idea, but do the disconnect and coupling at engine. see picture connect 5 and 6 together or cap off.
Jan 14, 2017 at 4:02 AM
JAMIE007
Thank you for the reply. Looking at the picture, Couldn't I just connect 3 to 4, then 2 to 6?
Jan 16, 2017 at 12:26 PM
JAMIE007
I did this and it worked great! No more dealing with those rusted out lines for the rear heat!???????? Super easy to do. Just loosen up the power steering reservoir and the coil pack and move aside then you'll have plenty of room to get the job done. I hope this idea helps someone else
Jan 18, 2017 at 6:30 AM
DOCFIXIT
  • 18,828 POSTS
Great job you were right miss typed 2-6 is correct. glad you got it fixed
Jan 19, 2017 at 6:49 AM
