Rear heater control valve?
125,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
ROBERT GIVENS
  • 5 POSTS
When replacing the rear heater control valve on a 1993 e-150 which way does the arrow point that's on the control valve? There is currently no valve it has a manual shutoff valve installed that someone put on when replacing the old one so I don't know which way the arrow points.
Mar 15, 2026 at 10:16 AM
  • 55,628 POSTS
So the arrow goes in the way the coolant flows, but it should work either way. Ken
Mar 17, 2026 at 2:02 AM
ROBERT GIVENS
  • 5 POSTS
Hi Ken Thank you very much for your help. I have one other question I want to change the rear axle lubricant does it require any additives such as a slip agent to the new lube? It's a 10 bolt rear axle and I believe a 3.55 gear ratio. Its a conversion van with a 5.8 lt engine.
Mar 17, 2026 at 4:00 AM
  • 55,628 POSTS
Yes, wee can help but we only handle one problem per thread, please post your new question here, you must be logged in.
Cheers, Ken
Mar 18, 2026 at 1:16 AM
