Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
E-Series Van
Climate Control
Air Conditioner
Hose
Repair rear heat and A/C
1996 FORD E-SERIES VAN
150,000 MILES • V8 • 2WD • AUTOMATIC
TED ROGERS
MEMBER
Someone has disconnected the rear heat and AC. Is it hard to fix? Can you just run hose to a good connection spot?
Oct 5, 2018 at 9:55 AM
Experienced Mechanic
Yep, run new AC and heater hoses and the system should start working just make sure the rear evaporator and heater core are not leaking.
Cheers, Ken
Images (Click to enlarge)
Oct 7, 2018 at 5:23 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
