When my sons driving, it feels like the back is swaying or wobbling. What could this be? Please and thank you.
Jan 21, 2019 at 2:35 AM
D6SPAN
✓Experienced Mechanic
Hi!
My first thought would be to check the wheel studs. They can, in time, become stripped and need to be replaced. The lug nuts should snug down, but if it seems they are spinning, then they are stripped. I would look at your sway bar links at the rear of your vehicle. These are both fairly inexpensive to replace.
Let us know if there is anything further we can help you with!
Jan 21, 2019 at 6:39 AM
This can happen because you have a tire that is coming apart. Please jack up the rear of the car and spin each tire to see if the tread has a bubble in it. Here is a guide to help raise the car:
