rear end shaking and sounds like a grinding noise inside the car
180,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
ANGELA1982
I bought my ford explorer back in 2007. I haven't had to do any work to it except for the normal stuff...like oil changes, tune ups, breaks, tires, etc. After about a year or so, the rear end started to shake real bad. You could feel it inside the car, but it would only do it in the winter time as I recall. Cant quite remember but something like that. Now almost 7 years later it has gotten worse. Everybody that gets in my car is like.." Are we going to make it?" Or "Is the rear end going to fall out?" Its really that bad. So I took it to a place called Discount Tires, and the pretty much guessed and said that it was my wheel barren on the right front. So I had them replace it.. Then I left still doing it, so I returned the next day. And well they said it was the rear driver side wheel barren so I had it replaced. Drove off it still was doing it. At this point I am so mad and have no clue why they couldn't tell me what was wrong and why they were just wanting to replace whatever they could. Made no sense to me. Anyways. I took it finally, to a place I have gone to in the past and they said I had the wrong type of oil in my rear end differential (CHUNK), and there was too much oil in it. So they told me to replace the oil and add an additive. So I did all of this. the noise and shaking stopped for two days now its back... please help me figure out what this could be. Do I need to replace the pinions and stuff inside the rear differential (CHUNK)? And if so will this help? Also, one more thing, Is this hard to do yourself, or Is this something that needs to be taking to some mechanic shop to do? please let me know what I can do.....I have spent a lot of money and running low on funds for this.
thank you so much, angela
Mar 21, 2014 at 2:52 PM
HMAC300
  • 48,601 POSTS
Discount tire is a tire store not a place where they fix it. from your description it may be ujoints or a rear end. take it to a place that has a good mechanic and he can test drive it to actually feel the problem for a better diagnosis. I would lean towards a bearing in the rear end like pinion bearings or difff bearings which a QUALIFIED mechanic should do. This is n' much but unless ic ould test it myself it is the only thing I can suggest right now without looking at it myself.
Mar 22, 2014 at 12:05 AM
ANGELA1982
Thank you for getting back with me...Discount Tires not only changes tires but they also fix stuff too. But its like they second guess things too. They did test drive it and they told me that it was a wheel barren...Nope that's not what it is....Its something else. Its in the rear you can feel it.....just want to thank you so much for getting back with me....I have had three people test drive it and nobody can give me a straight answer...but thank you so much....angela
Mar 22, 2014 at 4:37 AM
HMAC300
  • 48,601 POSTS
usually the noises you describe are either a drive shaft problem like ujoint or the rear end unfortunately the rear end has to be disassembled to see what is wrong with it if that is the case. If you haven't had it to a trans shop have someone there try it as they also do rear ends etc. they may be able to find it or give a better opinion.
Mar 22, 2014 at 4:55 AM
