Rear end problem
174,218 MILES • 4 CYL • AWD • AUTOMATIC
JACKIE93
When going a low speed like ten mph or less if you push down on the gas pedal just a little bit it seems like the rear end jerks. But only does it at low speed when you push on gas pedal.
Aug 11, 2017 at 7:51 AM
  • 55,740 POSTS
This could be becasue the rear differential is low on fluid or needs to be serviced. Here is a guide that will help show you what you are in for when doing the job.
https://www.2carpros.com/articles/differential-service
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Aug 14, 2017 at 6:43 AM
