rear end noises and truck vibrates
246,674 MILES • 4.0L • V6 • 4WD • AUTOMATIC
JOVITA39
my explorer shacks when you get to the speed of 55 till about 70. I have replace the rear tie rods , and the bearings in rear and front hubs and bearings. can you please help me with this because I have spent over 1500.00 to repair this problem and still have it. also have replaced all tires and rims. thank you
May 8, 2014 at 8:51 AM
HMAC300
  • 48,601 POSTS
check the ujoints in driveshaft that sounds like the problem. also check motor mounts. there is a tsb on this but it should have had this problem a long time ago it says something about lengthen driveshaft. but check ujoints firs if you see rust around seals replace them.
May 8, 2014 at 9:02 AM
