Sep 2, 2022 at 4:50 AM
PJW1977
MEMBER
So, you don’t think it has anything to do with the differential? Is there any danger with driving it like it is?
Sep 2, 2022 at 9:47 AM
PJW1977
MEMBER
Also, it does it when I’m not using the brakes.
Sep 2, 2022 at 9:52 AM
✓Experienced Mechanic
Yes, I would not drive it with that sound, it could cause the wheel to lock up, the noise will happen whether you are using the brake or not because the E brake shoes are drugging on the inside of the rotor (drum part) please check out the video I sent you so you can see what I am talking about.
