Vehicle's rear end has a knocking/clicking sound whenever drive slow or drive in reverse
241,121 MILES • 4.7L • V8 • 4WD • AUTOMATIC
KYLIE JONES
Hi! Mainly hear and feel it in reverse. Sometimes it's to the point that I can feel it resisting. I continuously check the rear differential fluid, but most of the time it full. When it does need fluid, it's just a couple table spoons if that? Any ideas on what it could be? It's been a problem for about a year now. Its slightly getting worse but at a slow rate. I hate the idea of having to replace the entire rear end. Thank you so much for reading!
May 21, 2020 at 12:32 PM
  • 110,248 POSTS
Have you checked the universal joint? It could be binding and causing the issue. Take a look through this link. It explains how one works. Before the differential, I would remove the driveshaft and check the universal joint.
https://www.2carpros.com/articles/how-u-joints-work
Here is a link that shows in general how to remove a universal joint:
https://www.2carpros.com/articles/how-to-remove-a-drive-shaft
May 21, 2020 at 12:54 PM
