Rear end, tires do not turn when the transmission is shifted into drive or reverse?
100,000 MILES • V6 • 2WD • AUTOMATIC
EDWARDMITCHELL9
Tires will not turn when put in drive are reverse.
Jun 5, 2025 at 2:19 AM
  • 55,711 POSTS
Okay, I would first raise the car up in the rear on level ground, here is a guide to help:
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
With the parking brake off and the transmission in neutral you should be able to spin the driveshaft, this will tell us if it is the transmission or differential is having the issue. If it spins, lower the vehicle and check the transmission fluid level.
This guide can help you with that as well:
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Please upload pictures or videos in your response of any problems so I can see.
Jun 6, 2025 at 7:29 AM
