Rear end swap
18,600 MILES • 5.3L • V8 • 4WD • AUTOMATIC
HAIRBRUCH
My truck is a 1500. i would like to to put a 2005 rear end in it even though it is 1" shorter than the 2008. will it work or do i have to do some modifications?
Jun 15, 2019 at 12:04 PM
Good morning,
No, it will not. You need the exact differential with the exact dimensions.
Otherwise, the truck will not track correctly and the ride will be affected.
The gear ratio must also match the front as well.
Jun 15, 2019 at 9:41 PM
HAIRBRUCH
What if the differential gear is one size bigger?
Jun 15, 2019 at 10:56 PM
HAIRBRUCH
The gear ratio in my truck was a 3.72. i want to put in a 3.41 ratio.the carrier gear is the same size but the pinion gear is just one tooth more than the 3.72. what would happen?
Jun 16, 2019 at 1:07 AM
It would not stay in four wheel drive. It would pop out and damage the transfer case.
Jun 16, 2019 at 1:13 AM
The gear ratios must be the same. You need to find an exact differential to replace.
Jun 16, 2019 at 6:48 AM
