Rear end
186,000 MILES • 4.3L • 6 CYL • RWD • AUTOMATIC
JON COLOMBO
Slips sometimes then clunks sometimes and hum, sounds like old school bus! Clunks when coming to complete stop also. Checked u-joint no play!
Apr 20, 2017 at 3:37 AM
HMAC300
  • 48,601 POSTS
try twisting drive shaft back and forth it may be the gear set is worn out and you will have a lot of play or the shims behind spider gears are the same causing that. it may be low on fluid which you should check as well.
Apr 21, 2017 at 12:21 AM
