rear drum single return brakes
90,000 MILES
BUICKBOY
I need an exploded view of rear drum single return spring brakes & how do you reattach thatspring. Looking for instructions on this replaced shoes adjusted now pedal goes to the floor it will pump up with 2-3 pumps but no e-brake not my first brake job but lost
Apr 30, 2013 at 7:30 AM
DUGSMOBILE
  • EXPERT
  • 38 POSTS
They actually make a special tool for that. If not doing a bunch of these save your money. Suggest vise grip and big screw driver, somewhat neanderthal but works. the adjustment is tough becase there is supposed to be a knockout in the drum you remove to get to the adjuster but they wern't on all of em. turn adjuster out till you can just get the drum on without it binding up. put drums(both) on then press pedal 30-40 times. Then use the parking brake about 5-6 times. see how that works, As shoes expand the lever with the spring on it will tilt, turning the self adjuster when it tilts far enough.
Apr 30, 2013 at 7:07 PM
BUICKBOY
Thanks, I tried all that but still the same thing I'm going to try bleeding them no fluid loss or leaks though only thing I can think of to do ANY other suggestions would be helpful I kinda need brakes haha thanks
May 1, 2013 at 3:14 AM
