Rear drum brakes
127,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ALEXLOVE89
Okay, so another question I need help with on rear drum brakes. I’ve been searching for rear drum brakes and I wanted to get a good set with some corrosion protection on it, when I am shopping for them on every site there is all the ones with protectant on it say they are set with the Sebring 2 door coupe I have a 4 door and the only 4 door ones are the basic non coated ones. Now if I have to I will just buy the basic ones that are labeled for the sedan but are the coupe rear drum brakes the same as the sedan ones? If so I could just buy the nicer coated ones for the sedan, I checked measurements on the size of the drums and they seem to be the same size for the most part but sometimes don’t look the same. I could just use a pro perspective as I am always learning and enjoy working on cars. Thanks for your time guys!
~Alex
Oct 5, 2020 at 8:13 PM
  • 110,251 POSTS
They are two different drums. The coupe used a Mitsubishi style drum and the sedan used an American type.
Here are the OEM part numbers:
Sedan
4779286AA
Coupe
MB895659
Honestly, they are not interchangeable.
Apr 2, 2021 at 2:50 AM
ALEXLOVE89
Yes, this helps me thank you!
  • 110,251 POSTS
You are very welcome. Please feel free to come back anytime in the future if you need help or have questions.
