Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Drivetrain
Differential
Axle
Seal
Replace/Remove
rear bearings replaced somehow the seal went bad?
2015 FORD F-150
65,000 MILES • 3.5L • V6 • TURBO • 4WD • AUTOMATIC
KFLY
MEMBER
I had the rear bearings replaced on my truck a month ago. Somehow the seal went bad and now I need to replace it myself. Thank you! Kevin
Feb 7, 2020 at 10:54 AM
Experienced Mechanic
This video shows the job being done on a similar car but the process is the same.
https://youtu.be/ytqXLSjHNm0
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/rear-axle-seal-replacement
Feb 7, 2020 at 11:02 AM
PORTAFISHING
MEMBER
You will need to remove the brake caliper
https://youtu.be/VsMD6QR_KrY
Image (Click to enlarge)
Feb 7, 2020 at 11:18 AM
KFLY
MEMBER
Thank you all for the quick response. I will try to get it up on stands tomorrow.
Feb 7, 2020 at 11:51 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
