Rear driver side turn signal and stop lights are not working?
2000 DODGE DAKOTA
250,000 MILES
DIESEL360
The driver's side turn signal and stop light were not working. Got it working intermittently by messing with pigtail connections. Fuses good.
Apr 23, 2023 at 7:50 AM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
If you were moving the wiring around, chances are you simply have a poor connection. However, in most cases, the light socket is the problem.
Do me a favor. I attached a pic below showing the wiring at the light. First, using a multimeter, see if there is continuity to ground at the black wire. When testing, move the wire around to see if it changes. If that is good, check the other two wires for power in the socket itself. If there is power, replace the socket. If there is no power, back probe the wire from behind the socket to see if power is present.
Apr 23, 2023 at 9:00 PM
