Rear door will not close
169,000 MILES
BARBARA FRAPPIER
  • 10 POSTS
Have used screwdriver and latch is in open position. Sprayed silicone on latch, but it still will not latch when door is closed. I can move latch into closed position manually but striker in jam will not cause it to move.
Jan 1, 2018 at 8:50 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
It sounds like the door latch is broken and needs to be replaced check out the diagrams below to show you how to change it out.
Also if the door is not aligning with the striker, then the door hinge bushings are worn out causing the door to sag.
If the door is aligning with the striker, then perhaps the striker needs to be adjusted, in or out or even up and down. But if down, most likely that is the result of what I said before and the door sagging because of worn hinge bushings.
The striker on the other hand may have a torx head and if it does, since they are usually very tight, I use the proper torx bit and an impact to loosen it up.
Then tighten by hand just enough that it will still move, but hard to move and close the door so it moves the striker to where it has to be, the slowly open the door, trying not to move the striker, then tighten the striker with the impact, and try it a few times to make sure it is okay.
Jan 1, 2018 at 9:56 PM
BARBARA FRAPPIER
  • 10 POSTS
The striker is a single “U” shaped piece and is firmly attached to jam. The door does not seem to be sagging and the striker appears level. My mechanic fixed it once in a matter of minutes by spraying the latch with a lubricant and voila! It worked. I have not had similar luck.
Jan 1, 2018 at 10:26 PM
BARBARA FRAPPIER
  • 10 POSTS
P.S. thank you for your earlier suggestion.
Jan 1, 2018 at 10:27 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
If you can open and close the latch like you were saying "I can move latch into closed position manually ", then the problem is not the latch, it must be the striker. Here is the adjustment procedure from the repair manual.
Jan 1, 2018 at 10:36 PM
BARBARA FRAPPIER
  • 10 POSTS
Below is a picture of the striker. It does not look like the picture you sent. Am I looking at the wrong thing?
Jan 1, 2018 at 10:46 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
It looks exactly like that. I sent two pictures, try the first picture.
Jan 1, 2018 at 10:52 PM
BARBARA FRAPPIER
  • 10 POSTS
Okay. Will try fiddling with striker. Have to find “star” tool to loosen screws. Will let you know how I make out. Wish me luck. Thanks again. Barbara
Jan 1, 2018 at 11:02 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
That is called a torx.
Jan 1, 2018 at 11:05 PM
BARBARA FRAPPIER
  • 10 POSTS
Ah! I have learned something new. It is good that know the proper names instead of relying on whatchamcallit or gagiponus. Thank you.
Jan 1, 2018 at 11:07 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You are welcome. They are not that tight, so you will not need an impact like I said previously, they are just 18 foot pounds (ft lbs).
Jan 1, 2018 at 11:11 PM
BARBARA FRAPPIER
  • 10 POSTS
Found a torx but it is too small. Obviously do not want to strip things. Will look for bigger one. Just in case it matters, while I can move the latch manually with a big screwdriver it does take quite a bit of effort.
Jan 1, 2018 at 11:14 PM
BARBARA FRAPPIER
  • 10 POSTS
At some point I am going to give up and take it to someone like you who knows what they are doing and has all the right tools at hand and have them fix it.
Jan 1, 2018 at 11:17 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Okay, that is up to you. Good luck!
Jan 1, 2018 at 11:29 PM
BARBARA FRAPPIER
  • 10 POSTS
You have been wonderful! Thank you again. Barbara
Jan 1, 2018 at 11:49 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You are welcome!
Jan 1, 2018 at 11:59 PM
BARBARA FRAPPIER
  • 10 POSTS
Went to mechanic. Latch broken. Pulled fuse so interior lights would not go on. So far after market latch $190.00 more or less and it has to come from Canada. End of saga. Thank you for all your help.
Barbara
Jan 2, 2018 at 1:07 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
The left rear is part # 15110509 and the right # 15110510.
Here is # 15110509 on ebay for $125.00 and free shipping,
https://www.ebay.com/p/GM-OEM-Rear-Door-lock-25948724-15110509/655497849
Jan 2, 2018 at 1:21 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
2CP-ARCHIVES
  • 4,540 POSTS
the latch on the rear door is not allowing the door to close. what can I do?
Feb 5, 2019 at 2:13 AM (Merged)
JDL
  • 16,098 POSTS
Is the door bouncing off the catch post? You might be able to flip the latch up to catch the post. I can't see much from here?
