rear door will not open
170,000 MILES • 2.2L • TURBO • 4WD • MANUAL
RUFUSBARRY
The rear door will not open. The rods to the lock and actuator go back and forth, but door will not open. Regards, Barry
Oct 17, 2017 at 1:17 AM
  • 31,937 POSTS
Tricky problem as you will have to get the door trim off with the door closed, as i feel that the door actuator has failed of a link rod has cone adrift. probably a job for a mechanic or someone with some good skills as this is a difficult task with the door closed.
Oct 17, 2017 at 10:30 AM
RUFUSBARRY
Thank you for the advise ,very helpful Barry
Oct 18, 2017 at 1:03 AM
