Rear automatic door will not open with key fob?
265,000 MILES • 6 CYL • 2WD • AUTOMATIC
DPG7466
When I try to manually open it, I can hear the latch unlock but relock and draw the door closed when I try to manually life the rear door.
Nov 22, 2022 at 10:54 PM
  • 110,251 POSTS
This could be the result of a couple of things. First, are you able to make it work correctly from inside the vehicle? Is it only the FOB that is not working?
I ask because there is a liftgate module and a full-open switch in the circuit. The problem could come from either of the two.
Do me a favor if possible. What I would like you to have done is the scanning of the can-bus circuit. CAN stands for controller area network. Basically, all the different modules are tied together via a few wires. In this case, the liftgate module is my focus. This type of scan will identify codes regardless of the module storing them.
Here is a link showing how it's done:
Let me know if that is something you can do or have done. Also, let me know if the door only malfunctions using the fob.
Nov 24, 2022 at 11:49 AM
