Rear Door Locks
98,000 MILES • 3.6L • V6 • RWD • AUTOMATIC
JAMES_DEHAVEN
The rear door locks are not working, electrically, wroth the remote or the buttons on the front doors.
The manual, push-pull knobs work fine.
Both front doors lock & unlock just fine.
I have checked power on both sides of fuse, battery voltage is there.
Apr 18, 2016 at 8:03 AM
HMAC300
  • 48,601 POSTS
get it scanned for codes it can be a remote receiver problem or a body module problem, probably the latter. you can check the dk blu/wht wire it supplies power to both doors to open.
Apr 18, 2016 at 8:41 AM
JAMES_DEHAVEN
I have a Solus scanner at work. I will try that.
Apr 18, 2016 at 10:12 AM
